car overheats. needle goes past H. underhood smokes. i replaced t-STAT.
Still overheats bad. smell coolant. when i let off da gas for da first time temp needle jumps to H and engine bogs a little at about 30mph. removed a/c a while ago. problem just started. ima flush it in an hour or so! is that enough info to pinpoint da problem? will let you know how flush went.
