Im wondering if anybody has a APEXI AVC wiring diagram. The controller that i got didnt come with it (used).
Apexi Avc Wiring Diagram
You try the apexi site? Usually they will have soem in PDF format. I told my buddy to get his from the website when he got his VAFC.
Umm i Can try to dl it for you and try to upload the main pages to wire it up if you want. You know how to set it up right?
Or hell i just modify it lol heres the pinout if you need to know how to use it just tell me.
Ahh sorry forgot one more this one is important Grounding and stuff dunno why they have two separate grounds on this so beats me. But here it is :
thank you so much. this is a big help. what me and a friend are going to do is take his vafc wiring diagram that he got with his controller and use that and also use this. we are going to hook it up the same way as if you was were going to use vtec but with out vtec
it should work, ill let you know how this go.
Sounds good. Yea its somewhat similar. Mine had two grounds wire colors were about right but yea gl with it.
OK so what i got is a lil confusion heres what i got from the VAFC wiring
VAFC SAFC (from up top)
red wire- IG power red wire- IG power
black wire- ground green wire- ground
brown wire- ground black wire- ground
green wire- rpm purple wire- rpm/injector signal
gray wire-throttle (tps) green wire- throttle signal
white wire- speed signal
MY SAFC WIRES
red, black, brown, yellow, white, green, gray wires are all useable.
pink, blue, and orange dont look useable
see the problem here is that im confused, i have 10 wires off the safc, it looks like im going to not use 3 wires(pink, blue,orange). the white and yellow wires is the ones that im confused at. i DONT have a brown wire or a purple wire. im thinking that im going to use the VAFC diagram cuz this looks more useable in my eyes.
Ohhh when i install my VAFC I had to cut 3 wires and connect it to that. Theres a part where it says you cut the wire and put one part of the wire on one and the other on another color wire. SHit I forgot what mine was. Its like one goes in for like input and one goes for output. Sorry a bit hard to explain. It should be on the VAFC diagram where it has the X marked on the wire colors going to the ECU like the third pic I have up there.
Haha thats good to hear. The double ground is interesting lol still havent figured out why they do it on my VAFC. I was thinkin bout doing both together but since every damn page in the manual said to do it separately i did it separately. Let us know how it works Show some pics
