I tried starting up my cr today and it turned but it wouldn't turn over,so I went for the basics spark and fuel.I took off my fuel line and put a paper towl thrue it.I tried starting it also pumping it with gas and the paper towl was drie.So I was wondering what you guys think.I am thinking the fuel pump.Were is the fuel pump? Do I need to drop my gas tank? Thanks
No Fuel.HELP!!!
It may be the fuel pump or the main relay. Do U hear the fuel pump engage when U turn the key to ON. Try to listen to that sound. If there's no sound, U fuel pump is out.
The fuel pump is in the gas tank and YES, U need to drop the tank.
Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
have you been to the gas station lately?
its probably the pump or main relay, check the relay first, its easier to fix
If its what I am thinking of than no. That is your fuel sending unit. Your main relay id under the dash near the steering column. Do a search on here for main relay and there will be a diagram of exactly where it is.
Suggestion....go buy a haynes manual..it will tell you everything you need to know.No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
Originally posted by seigneur_raydenIt may be the fuel pump or the main relay. Do U hear the fuel pump engage when U turn the key to ON. Try to listen to that sound. If there's no sound, U fuel pump is out.
Yo...I don't hear the fuel pump engage at all when I turn my key ON....BUT it starts....and thats in the middle of the night ( 4am )..when everyone is sleep.....QUIETNESS...best time to work on your car!!
rayden...got a question for you.......
you think a MECHANICAL fuel pump would work better than an ELECTRICAL one????92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
Yes that brown thing is your main relay. Pressing the Accelerator while cranking does not help the motor. The only time you pump an accelerator is when you got a carbureted car.
Do you have cruise control? I forgot if the cruise control is a grey wire havent been under my dash in a while.
Originally posted by SuperTuner12010So that might be my cruise control,cool.
So how do I test my main relay?
Thanks!!!
Originally posted by SuperTuner12010So you just sodered the wires directly to the main relay?Is it posible for the actual main relay to be bad?Thanks
