squecking noise
    squecking noise
    ok guys. driving is my work so i know my car. i hear this squicking noise from the right front tire. it does it everytime i turn the steering wheel and everytime i go over small bumps. i mean i have this problem for the past 3 months. the shock looks good and everything is fine. i think the noise comes from the middle of the wheel. DO U GUYS HAVE ANY IDEA of what it might be.
    might it be a lower bolt joint. because when i turn the steering wheel the only movement one the tire is on the steering arms and on the lower bolt joint ( UPER CONTROL ARM IS NEW) >>> if this helps before i changed the uper control arm my iner tire get wear off.
    i need help man. that squicking noise is driving me crazy. i am about to open the whole wheel and shock and spring and beat the shit out of them>>>>> just to get my rage out man.
    its probably the strut needs changin or the cv joint is worn did you inspect it.
      this may sound retared.. but u sure its not ur brakes??
      i have a squeaking right now and i know its my brakes...
      go drive ur car and when ur turning.. apply light amount of braking and see if the squeaking goes away.. if so.. u may need new pads or stop sqeak for the pads
      Praise The Lowered...
        it's not the brakes. the car handles good on turns so i don't think is the straus. the thing is that everything is good except for the noise.
        anyother ideas guys. this noise is driving me creazy
          i been told that it migh be the brake dust pan. but where does that shit touch. because i hear the noise everytime i turn the steering wheel and everytime i push or pulll the right side of the car. i mean i have been under the car while someone else turned the wheeel and i haven't seen anything.
            i had the same problem, its ur upper control arm or upper and lower ball joints or it could be both.
              well since i have new uper controll arms>>>. then it might be the lower bolt joint. someone at honda-tech.com told me that it might be the brake dust pan. and it sounds like that shit. shit man i don't know what to do. $60 for two lower bolt joints. that is creazy. anyways hopefully i will open the wheel asembly on sunday and see what is wrong with it.
                for future references (for the ones who search)
                it was the lower ball join.
                  yea its your upper or lower ball joints common when the weather gets cold and it rain and snows. first i would jack up the car take the wheel off and spray some lithium grease or wd-40 on the upper and lower joints. if that dont work then u need to replace on or the other. just to be on the safe side make sure u inspect the ball joints even if the lube works
                  honda life 4218
