when my car is at idle.the idle goes up and down shaking the car and sounds like its missing-putting.also when i hit my brake my the idle raises from like 9 to 14 the more i hit the brake the higher it goes.I have checked all vacumme lines and they are fine. new plugs,wires,cap,rotor.this all just started after i bled my brakes and its getting worse. my car has 4 wheel disk and abs.
irratic loping idle "help"
check your line to the map sensor,i think its 21,its in the black box on the firewall.could also be the fast idle thermo valve.pcv valve.Last edited by 91accord4door; 03-24-2004, 09:03 PM.
