idling in drive
    idling in drive
    I have a problem. When I was driving to day and stopped at a light my car started to idle pretty bad. (the rpm neddle kept going up and down). The strange thing was i was in drive when it was doing it, usually ity does it in park. What do you guys think the problem is. A new sensor maybe. Appreciate the help
    Peace
    Car: 1990 Honda Accord EX 4dr
    I think there is another thread on this use the search
      but sounds to me like a vacume leak,and it could also be your fast idle valve,check that clean it,theres a diy on cleaning it that accordztech made.but check all vacume lines.good luck.maple gotta help out a little better than that.
        idling in drive
        Thanks for all the feedback. I will check the vacuum tubes tommorow. Thanks again
          no problem,check the ones that go to the black control box located on the passenger side firewall,and the ones coming out of the intake/throttle body!good luck.
            idling in drive
            Now that I think about it, would this idling problwem have anything to do with me recently putting in pulleys, a fuel pressure regulator and a fuel rail? Thanks
              idling in drive
              Got the problem fixed. Turned out there was a hole in my filter for my intake and it was sucking in to much air. Thanks again for all the help.
