So here are my symptoms over time. I already know it is the under dash fuse relay box as when i took it out and started to remove it the minor electrical issues have been having appear and stop and reappear as i move around the box itself. I am about to cut that srs plug and take whole thing out but in meantime here are my issues.
1. Chime box for headlights on comes and goes.
2. Battery warning light comes on and off. And now after half removing box and putting it back on it stays on. There is nothing wrong with charging system I have a volt gauge and strong battery and alt.
3. Sometimes when i open drivers door it turns on dome light and sometimes it dont. This is also cause of box. I can even kick box sometimes and get it to work and go off.
4. My left rear turn signal doesn't work now after removing and putting box back on. Bulb is fine and so is fuse and switch.
5. Ac clutch relay doesn't work and ac doesn't cut on. Just started but on occasion it would not work then work for long periods. Just started after removing and putting box back on. Nothing wrong with ac system. I can move box around and get it to work. Ac system has also been rebuilt in last 2 years.
I am going o track down what plug these systems go to and i am assuming something back there is cutting into wires or something. Or maybe just a common bad ground or common power to all these relays(most likely i think). Anyone have any good insight?
