major malfunction customers car
    Hey everyone someone on the board needs your help. Its a 90 honda accord lx. Here are the main problems
    1)automatic seatbelts dont roll up anymore.
    2)windows dont roll down
    3)No check engine light nor lights come on at all when you turn the car in the on position
    4)cluster displays no speed,temperature guages doesnt work,gas guages doesnt work,rpm guage doesnt work
    5)no turning signals only hazards work
    6)rear defroster doesnt work
    7)Automatic shift lock doesnt release.
    Any takers?
    fuses all good?
    same with the grounds?
      hmmm dead battery?
        could be grounds??
        fould up electrical system?
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          Originally posted by N9netwoAccord
          fuses all good?
          fuses are good i checked them all the grounds are all tight no tears or cracks
            Originally posted by Ralphie
            hmmm dead battery?
            battery is straight I Just changed it last week brandnew from strauss
              Any takers?
              1)seatbelt motor/pulley is seized?
              2)regualtor is kaput? window off the track?
              3)Guage cluster is done and/or VSS?
              4)"
              5)"Hazards work b/c that's a seperate line
              6)probably was tint before, scrapped off lines of the defroster...
              7)Cable for the auto shifter is warped?
              1990 Accord Lx F22a1(Daily) SOLD - will be missed
                4)"
                1 Its been checked not sure if it siezed
                regulator just doesnt go kaput like that both of them went at the same time
                the vss isnt unplugged I think its the tcu
                  try checking the relays. later.
                  Avoiding dirt at all costs
                    The gauge sounds like it is done for...a lot of the signals go through the gauge cluster; such when the door closes, the belt(s) retract... as indicated in the car diagram in the cluster...
                    weird?
                      Ahhh Mike did you call earlier? Is this AZUL's whip? It sounds electrical...maybe the battery fuse blew?
                      Originally posted by lordoja
                        It really sounds like a grounding problem. Since you already checked all id check again just in case.
                          check the fuse under the hood that supplies all the power to the inside. Should be a 40 or 50 amp or something like that. Don't just look at it, stick a meter up to and see if you have continuity from terminal to terminal.
                          Also check to make sure the connections to the fuse are ok.
                          Check the plugs goin to the the under dash connections to make sure they are all plugged in and no burnt wires.
                          For the grounds, use the meter to test for continuity to ground instead of just looking at them.
                          Test every wire in the underdash fuse box to see if any of them are getting +12V!!!! I'm guessing they all test dead!
                          It sounds like you are gettin 0 power inside the car so I'd lean towards underhood fuse box wiring or fuse issue. Or a connection between the u/h fuse box and u/d fuse box.
                          My Accord History:
                          91 EX 2dr : 91 EX 2dr : 91 LX 4dr : 93 EX 2dr : 86 LXi 2dr : 92 LX 4dr : 92 EX 4dr
                          -Patrick
                            For the Automatic Shift Release, make sure to check your Brake Pedal Switch. When mine went out, I could not shift into gear without using the key first. But it also affected my brake light indicator.
                            Taking over the world one drift at a time!
                              Problem found when 2.2azul was replacing the fuses under her dash where the kick panel was 1 of the fuses wasnt blown but was missing and it didnt have an indicator of where that fuse belonged to. There was no label that section saying where it belonged to was blank. She used the fuse for something else and that 1 fus was wired into everything. Thankgod glory found it. Now i gotta get my ass out there and help out with her altenator. glory went to a party. Now its jsut me once again. Thanks everyone for the support
