Well 1st off, i have an F22A6 and i got my head milled 45 thouands or .045... compression is ~9.5:1... compression check exibits 195-200 accross the board... when i 1st replaced the timing belt, i set everything at TDC... Crank at TDC, cam at TDC piston 1 and set the balance shaft and oil pump. Read on a diff thread (http://www.cb7tuner.com/vbb/showthre...=milled+timing) that timing needed to be advanced 1 degree per every .012 shaved off the head... i accordingly set my cam timing 4 degrees advanced... engine would start, but would stutter and jump like crazzzyyyyy, and no matter how far to each side i flipped the dizzy, i couldnt see anywhere near the 15 degree mark on the flywheel... i could only line her up with the TDC mark, which is fuckin wierd.... i experimented, i set the cam at TDC piston 1 and set the crank at 15 degrees BTDC to see how she reacts... she runs beautifully... thought it was extremely wierd, but hey, she ran and i got the timing dead on balls accurate by turning the dizzy allllll the way towards the front of the motor as much as she would go... shes been running beautifully till this day....
so to my initial issue... i have a custom turbo setup which is tuned with uberdata by me and SoySauce and at 1st, i had my rev limiter set at about 6000 to keep myself safe.... after a good base tune, i tried to crank up the rev limiter to about 6800 so i could open her up a lil more... she NEVER goes past 6000... its like she hits a fuel cut/ rev limiter... I'm GUESSING it has to do with the timing not being fully TDC, but i dunno.. i even rewrote a diff. bin. with the 6800 rev limit on a couple diff chips and switched em up and same thing! any ideas as to how i could at least get the timing propper without stuttering or bogging? and preffereably also how i could fix this ghost rev limiter issue?
All help is verry much appreciated... thanks in advance guys... and as always, sorry for the long drawn out post...
