Idle issues
    Idle issues
    Has anyone ever had this problem your driving after letting the car warm up everythings fine and all . You come to a stop then the idle starts to surge and lope up and down. Now ive checked this problem repeatedly. But I still cant find the answer or so I thought i did. Ive checked for vacuum leaks nada I reset the ecu nada,Ive checked the iacv and cleane dit same thing. Ive taken the fitv and cleaned that and winded the plastic wax cap all the way in and even pressed on the metalic part in the middle nothing.the odd thing about that was when i took the fitv off theres usually supposed to be coolant inside of it but i didnt see anything which is strange. Is there supposed to be coolant all in the fitv or in the middle part?
    Could it be that the ecu is bad or that theres a vacuum leak but i havent found it or perhaps its the mapsensor orthe throttlebody gasket is bad ive checked the gasket too no rips or tears on it or wrinkles. i havent bled the coolant at all but i let the car idle while it was warm and turned the heat up all the way and let it idle with the radiator cap completely off. What gives? I really dont need this shit not now being that im going to get my tranmission fixed too.
    What are your RPMs sittin at? IAC you can try getting a new one if that works or just borrow one off of a working car.
      problem found iacv I tossed that shit in the garbage. Pita that sensor is a tricky breed didnt even shoot a code and i bled the coolant too.
        The FIV costs about $55 new......how much does the IACV cost? I cleaned mine with no good results. I also adjusted the FIV with no results.
        When I start my car......it idles to 2100 RPM and I hope over time that will do no damage to the engine.
        1992 Accord Coupe 5-Speed
          woah!! 2500 that seems kinda high need to get that fixed buddy
          contact info
          (562) 324-3639 chan mao
