my e brake doesnt grip really well, when i pull hard, it slows down the car, but does not lock up the back tires. how can i change it so that it locks the rear tires? please let me know, thanks.
how do you tighten the e-brake?
Dont forget to pull up your e-brake a lil when adjusting.
replace your rear shoes/pads first before adjusting it. this is most likely why it isn't strong. you don't need to remove the center console to adjust. just remove the ashtray at the back and stick a 14mm i think in there and tighten the nut. after tightening make sure you have about 4-8 clicks on the handle. that's recommended.
[QUOTE=timmy0tool]replace your rear shoes/pads first before adjusting it. this is most likely why it isn't strong. you don't need to remove the center console to adjust. just remove the ashtray at the back and stick a 14mm i think in there and tighten the nut. after tightening make sure you have about 4-8 clicks on the handle. that's recommended.[/QUO
yea you shoulds replace the shoes or the pads first because i just had to spend $328 (that was my moneyfor my drop to ) on new wheel hubs and drums and shoes for both sides of the back of my car cause my mechanic showed me that when i would pull on the E-brake there was no rubber it was just the steel part of the shoe grinding on the drums and that the wheel hubs were gone already so learn from my mistake and either check them out or replace them before you adjust it good news about it is that my brakes stop and feel alot better after replacing the pads and adjusting the e-brake
________
Mercedes-Benz Buses SpecificationsLast edited by Davids92Accord; 04-09-2011, 02:27 AM.
CLICK ON SIG FOR MEMBERS RIDE
"2SIIC"
Authentic Jerseys for sale
http://www.cb7tuner.com/vbb/showthread.php?t=188314
Originally posted by JDM_EJI would have just bought a rear disc setup from an EX or SE...I got mine for $100...
________
Avandia PregnancyLast edited by Davids92Accord; 04-09-2011, 02:27 AM.
"2SIIC"
Most rear shoes are in decent shape and if yours is..... Jack up the rear end, remove wheels and rear drums. Adjust your brakes so that they have some/a little resistance. Then, remove the rear ashtray and use a 12mm deep-well (not 14mm) to adjust the tension on the parking/E-brake lines so that it locks up in 4-8 clicks is the spec for stock settings. If you do not adjust the rear brakes before doing the tension adjustment, they will not be as effective/responsive.
Originally posted by Davids92Accordyea i know i could of done that but i didnt want to waste any more time driving like before it gets even more serious and plus i just recently found out that my dads friend is giving us his 95 accord EX because the whole front end is messed up cause of the car accident he was in and my dad already called dibs on the stock rims so im gonna get the rear disc and convert it but until i make space in my back yard for that car to come in i dont have to worry about my drums in the back
