Power Doorlock Problem
    Hey Guys,
    I have a lock problem. My door locks LOCKS, but don't UNLOCK from the switch. So I have to unlock with key and by hand.
    heard it can be due to old, bad wire connections or something wrong with my powerlock unit, emulator or something.
    Anyways I can't install my alarm until this is fix, and I aint paying DEALER price for this little problem. I will take apart my door and see whats going on there. If I do need a part I will check back here, with people who are parting out.
    So if you have a similar problem now or before, advice and tips are very appreciated.
    thanks.
    Slam.
    I can accept failure. Everyone fails at something at some point, but I can't accept not trying". MJ23
    Time and Money BOTH is why I do what I do
    possibly the switch, im not sure.
    what u can do is get someones working switch and see if that helps....
    see with the alarm it hooks up to the stock switch i think, then it powers it with a positive or negitive trigger just like the switch...
    i think its tied into the switch or may bypass...
    just get someone elses and try it, if it works u know ur prob, if not then u can just start from there, look for a bad module or some wire.
    Retro!
    Hater
      Does the passenger door switch work?
      EGR Port Cleaning http://home.comcast.net/~em-engineering/T2T013.pdf
        YES, both side, driver and passenger switch do NOT unlock, only locks the doors.
