Somewhat recently my car had started hiccupping at lower rpm's or at idle.
Sounds as if it's skipping a cylinder, and my car bogs really low.
It also does it when I'm taking off from a stop... unless I give it a LOT of gas, which in turn has been eating my clutch.
Could it simply be my timing? (new timing belt installed 6k miles ago)
I dont think it's a headgasket cause my oil looks fine, car runs at normal temps, and I'm not spitting any more white smoke than usual
Spark plugs are new 3k miles ago... NGK at a certified Honda shop.
Plug wires are a bit old, but they look good... they're also NGK.
Car still has all the power (I think) at higher rpms in the fun-zone... it just hiccups really low at lower rpms.
Any ideas would be grately appreciated.
-Ben
www.shnflac.net
-Ben
www.shnflac.net
