How can you tell if the IABs are opened?
Rev the engine and have someone tell you whether they open or not. Or, if you have a video camera and/or no friends, point the camera at the lever and start taping.
Or you could try rigging a complex array of mirrors......
you can just open the throttle plate with your hands and try to rev the motor up until you see the diaphram (spaceship-looking thing) move to the open position.
when your car is off, the diaphram leaves the butterflies OPEN. when you start the car the vacuum created closes the butterflies. at the right rpm, around 4k, there will not be any vacuum thus opening the butterflies.
Theres a rotor similar to the throttle rotor on the right side of the intake mani. The IAB diaphram is connected to it. If you can open and close that rotor when the car is on the IAB's are open. To test if they open up just have someone slowly rev to 4800rpmKnowledge is power...in EVERY sense of the word
