ok just last month my cruise control work now when i set it, it wont come on. any one else have this problem, also what are some faulty pieces in this system, i heard it has a relay
criuse control problem
When I bought my CB7, it had the same problem -- the CC lights came on (both the button and the dash light) but it didn't actually do anything.
I didn't give it much thought because I rarely use Cruise Control. Until...
Months later, my VSS (Vehicle Speed Sensor) started going bad and throwing CEL code 17. I replaced the VSS and the next time I started my car... Cruise Control worked.
Have you been having any problems with your VSS? That could be it. My cruise control didn't work even when my VSS appeared to be working fine but once I swapped in a new VSS, it was golden.
Good luck!- Ghosty
WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
first, check all fuses
then if nothing, it's either your cruise control unit outside under your hood (maybe it's not holding a vacuum and therefore can't hold the throttle) or it's your little cruise ecm under the dash........the auto versions are known for going bad......you'll need another from an auto if you wanna try swapping it out........i'd try that and if it doesn't fix it, then i'd go ahead and buy a cb7 with h22a and sell that piece of shit to someone else
probably the brain though (cruise ecm)....and on the 7th day, deevergote rested and called his mom.
My dad's CB9's cruise control stopped working, and I was told to check if the brake and clutch sensor thingys (at the pedals) were out of adjustment, as the cruise control wont engage if there is any input from the clutch or brake.
Get up to speed, and then put your feet underneath the clutch (if you have 5spd) and brake pedals and pull up as you try to set the cruise control.
If it now works, you've found your problem. Adjusting it, on the other hand, is another thing.
...sorry for being so vague.1991 Honda Accord EX (Canadian)
Originally posted by pretty_ricky302ok just last month my cruise control work now when i set it, it wont come on. any one else have this problem, also what are some faulty pieces in this system, i heard it has a relay
Mine just did the same thing today .. and I dunno wtf ..
It was working fine last week .. Light on switch works fine .. light on dash
works as well .. I can step on the gas when the green light is on .. on the dash, but
when I do that .. the light on the dash goes out .. wtf ?
Howd you solve it?
Thanks
Tomi
