take off that center thing and then tighten the nuts..
lift the car to check and spin the tires, then pull up the ebrake slowly click by lick, by the half way click then u should start to see it grip
same for the other side.
u notice inside there is 2 nuts i think, one for each side, and on top of it there is one big nut. that is for adjusting the sides one by one and the middle one is adjusting all together.
That's really not the right way to adjust the e-brake. It should be done on the brake it self. Behind the drum there's a rubber plug. Pop off the plug and you can use a screwdriver to turn the adjuster. Turn it until the wheel spins around maybe once before it stops on its own.
Remember, if the e-brake has to be pulled up high that means you're not getting the full force of the rear brakes when you hit the pedal. Adjusting the handle only fixes the e-brake, doesn't do sh!t for when you need to slow down.
no thats not right. the right way is the 2 bolts behind the center counsel like stated earlier. you only adjust the brakes at the drum whenever you replace the brakes. after that the brakes will self adjust to compensate for wear.
Originally posted by cb7-R no thats not right. the right way is the 2 bolts behind the center counsel like stated earlier. you only adjust the brakes at the drum whenever you replace the brakes. after that the brakes will self adjust to compensate for wear.
Self adjusters never work right. They always jam because of brake dust. I have yet to see a car where the self-adjusters work correctly.
EDIT: I would only adjust the handle if I knew the brakes were properly adjusted. Otherwise, I check the brakes first.
