i need to know if the cruise control button will light up after you push the button when in park ( and car is started )? the reason i ask is because i seemed to have f***ed up my cruise control button and am trying to resolder the connections with a gold plated wire, please answer thanks!
question on cruise control, please answer, very simple to answer
there is a light in the button...it lights up green in the button...and that can be on whenever...but u have to be at 25mph and then u hit the button on the steering wheel and the green light on the speedo cluster will come on. now if u have the cc fuse taken out of teh kick panel the light on the button wont turn on...i only know this cuz i dont have cc anymore, and the button lit up still untill i used the fuse for something else then it wouldnt light up...hope all this helps
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
Originally posted by bagoon316there is a light in the button...it lights up green in the button...and that can be on whenever...but u have to be at 25mph and then u hit the button on the steering wheel and the green light on the speedo cluster will come on. now if u have the cc fuse taken out of teh kick panel the light on the button wont turn on...i only know this cuz i dont have cc anymore, and the button lit up still untill i used the fuse for something else then it wouldnt light up...hope all this helps
My Bad. I thought you were talking about the steering wheel button. Forgot all about the main power button.
