hey guys i was just wondering how to adjust a bulb on the projector...the main headlight. is it adjusted by screws after you take the plastic piece off or what? i messed with it last night and the bulb is loose and every time i hit a bump it shoots to the ground again...well i was just wondering someone help me out! thanks!
adjusting the bulb on a projector?
you might be screwed( no pun intended). i used to have a set of those, and i messed with mine alot when i was bored, and i ended up fuckin it up. those screws that are used to adjust can be unscrewed. so if you tried to adjust too much, you might have actually taken the screw completely out of the threads. when i did that, i coulnt get it back in, and the projector just kept bouncing around like you mentioned.
imo, time for a set of jdm's
