ok, new rods, piston, and rebuild, put all back together, the car fluctuates up and down (revs) from 1k to 1.5k, we checked the codes, 10, 14, 22...we fixed the vtec and the code 14, still getting a 10. we checked for vacuum leaks, we even swapped in a new iat sensor from my accord to see if that was it. we cant figure out we are still gettin a 10, and y the revs are still fluctuating. we also bled the coolant to make sure there were no bubbles. we have no clue we have thought of everything...please help
need help wit h22
Originally posted by bagoon316ok, new rods, piston, and rebuild, put all back together, the car fluctuates up and down (revs) from 1k to 1.5k, we checked the codes, 10, 14, 22...we fixed the vtec and the code 14, still getting a 10. we checked for vacuum leaks, we even swapped in a new iat sensor from my accord to see if that was it. we cant figure out we are still gettin a 10, and y the revs are still fluctuating. we also bled the coolant to make sure there were no bubbles. we have no clue we have thought of everything...please help
i dont think the fitv has been, but he took off the iacv and made sure water was goin through it and cleaned it off or whatever you do...what do u mean re-set?? sparkle ill hit you up prolly tomorrow if we still need help...i work all day so nites is the only time i have to really work on it
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
check the tps and map ...these parts tend to go bad without throwing a code.....also check compression...<----learn that in school today....lol92 accord dx....traded
97 accord ex....traded
93 civic si ....stolen
96 tercel ....sold
97 ek hatch b17 ..traded
97 civic 4door b16 sold
04 tsx traded ...for a honda coupe (top secret)
new pistons and rings baby its runnin it jus fluctuates, you talked to him today so hopefully he gets it figured out...thanks though boss, now its my turn, fuggin timing or whatev the eff it is...
