I am running a FPR with gauge. I wanted to know what the stock injector can handle as far as fuel pressure goes. I wanted to up the pressure a little bit but I am afraid of blowing my injectors.
Fuel injector question
Originally posted by DjSpeedyI am running a FPR with gauge. I wanted to know what the stock injector can handle as far as fuel pressure goes. I wanted to up the pressure a little bit but I am afraid of blowing my injectors.
are you going lean? or do you just like to pay for gas? by the looks of your engine bay..i would put my money on the latter
LOL, no i am adding some more mods like a cam and such and I want to be able to up the fuel if need be. Its not like I am going to run outside and boost it to 70 psi, but after all the mods are done i may move it up to 42 max. Daily will prolly be in the 35-38 range though. Like I said I just dont want to blow an injector or something.No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
depending on the mods you are doing, you may want to consider bigger injectors. but if you are not going that crasy route yet, i don't think that your injectors can blow that easy. good luck.The beginning of a new era............................
if you just have some bolt-on's mainly then u could upgrade to a venom injector or something with about 10% more output. the venom injectors are about 264cc so u could go with an injector like that. unless u have turbo, very modded N/A engine or use the spray u may want to upgrade to even bigger injectors.
o and btw, with all the mods i have done including the fpr set to 40 and bigger injectors (264cc) i have gotten an average of a 6mpg increase. even with just the fuel rail, injectors and fpr (at 40psi) i noticed a slight improvement in mpg. mpg city is around 26-28. mpg highway is 30-34. highest i have gotten is something like 36mpg yey yey so don;t wry bout using a significant amt of extra fuel by setting the fuel pressure up even 4psi lol
No kidding....Well now My only worry is if i bolted the Adjustable FPR to my stock one well enough (its a universal type that i had to cut my stocker to fit this one on). I guess we'll find out once it all goes in. So I guess I will look into going up 2 40 psi. i just hope I got the right kind of gauge to work with my setup, but I wont know until monday or tuesday. I am putting all new o rings on the injectors though so at least i know it will be tightly sealed in the fuel rail.No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
it looks like its on there pretty good. Actually I couldnt get the nuts any tighter and one of them even stripped a little while bolting it on, luckily it was as tight as can go. i actually thought of putting some soder on the seams of the fpr where it comes together but that might be overdoing it. I guess i'll know soon if its leaking or not.No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
I jst snapped a bolt in the fuel rail. Oh well time to hit up the junkyard. and it looks like i Put the fpr on the wrong stock unit. I have a h23 rail and a f22 rail and I put the fpr onto the h23 stock fpr. Hope this all works or I am going to say screw it and sell this junk off.No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
