Yes I have a 90 Honda accord 2dr and I have an issue. Now it may not be a big one but to me it seams to be a pain. OK the other day I was driving my car down the street and it died on me, Well I went to start it and to my dismay it would not start so the first thing I did was check to make sure that nothing come loose and then began to check things out well I check the timing belt and it looks like it could be replaced but seams ok and then I decided to check my fuel pressure and it was fine and then I decided to check my spark well I pulled a plug wire out to see if I could get it to ark to see if I was getting fire and I got no response so I then decided to pull my cap off and start checking things. I started off by checking the cap rotor and they looked alright so then I did some more test and seen that my coil was getting spark. So from here I assumed since my wires have no spark and my coil does that it could be my cap/rotor so I replaced these. Well to my surprise this did not work and here I am now asking anyone out there if they know what could be the issue. I am leaning towards the igniter but I am not too keen on Honda’s so any help would be greatly appreciated
firing issue
well i got it going today! luckily i had a friend who had a parts car and i swapped distributors and the car fired right up. Now as far as what was the issue i narrowed it down to the ignitor based on the test i ran so if anyone else is having this issue check to see if the coil has spark if it does most likely its the ignitor
