Ok yesterday i adjusted my valves (intake, exhaust) according to alldata and now it seems worse. Does anybody know the corrects clearence specs in metric?
Valve adjustment clearence
Re: Valve adjustment clearence
Originally posted by dj justice
Ok yesterday i adjusted my valves (intake, exhaust) according to alldata and now it seems worse. Does anybody know the corrects clearence specs in metric?00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
when u pull out the feeler guage, it should have slight resistance, not hella tight or loose..
i needa do this, any tips?
heheWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
old post but i got to bump this up because i am having this problem too. I adjusted them since i had a leaking valve cover gasket so i did it while i was there and then i went according to haynes specs. apparently the valve ticking it louder now! does anyone else have this problem and knows the cure? a friend told me it was the injectors cuz it was a lil dirty so it struggles by making the sound. but then again it wasnt this loud before i made the adjustments.
.009-.011 In. (.23-.28 mm) on the intake side,.011-.013 In. (.28-.32 mm) on the exhaust side accord and prelude 2.2L
2.3L /.003-.004 In (.07-.11 mm) on the intake side,.006-.007 In (.15-.19 mm) on the exhaust side.........this is according to Mitchell service manual
but according to honda techs if they aint raisen hell leavem alone you could be askn for trouble but im not telling noone what to do just giving my 2 cents
to some that might be all its wourth.....lolF22A1:blew up
F22A1/H22:blew up
F22A6/H22: " "
F22A4/H22: " "
H23A1 boosted:blew up
H23A1:traded
H23A1/H22 built:still in progress (getting my feet wet)
drive it like you stole it
FCB7(FRANKENSTEIN CB7 CLUB)
do you need to raise both wheels of the ground?
i was thinking about this, but if it aint broke dont worry is what im thinking
Originally posted by shadetreecustom.009-.011 In. (.23-.28 mm) on the intake side,.011-.013 In. (.28-.32 mm) on the exhaust side accord and prelude 2.2L
its the same as the tranny oil. if its still red after 100k don't even touch it.
lolare we there yet are we there yet are we there yet
Originally posted by SenseiAccordold post but i got to bump this up because i am having this problem too. I adjusted them since i had a leaking valve cover gasket so i did it while i was there and then i went according to haynes specs. apparently the valve ticking it louder now! does anyone else have this problem and knows the cure? a friend told me it was the injectors cuz it was a lil dirty so it struggles by making the sound. but then again it wasnt this loud before i made the adjustments.
cheap good torque wrenches huh? best bet for cheap is ebay but not garaunteed to be good LOL. otherwise i would go with craftsman from sears. think its like 70-80 bucks over there. they are good and pretty cheap. otherwise i would go with snap on torque wrenches. they are expensive but of course... snap on tops them all.
