how to install a ECU?
    how would i install one? i know how to take it out..but what about electricity etc
    should i disconect the battery and wait or discconect it and start taking it apart?
    im not dumb, i know to take out the battery but there is sometimes still some power in the system.
    thanks for your help.
    Retro!
    Hater
    You have to unplug the both sides of the batter just to be sure. And then you need a ratchet wrench they are 10mm bolts you need those to take off the protective pan that holds the ecu in place. Then its not that hard to take the connectors out of the ecu you have to unplug them.
    I used a flathead scredriver to hold pry it from the ecu when i hold the release button clip down cause to do both at the same time is gonna be hard.
      damn its a bitch!!! i got the tcu connectors out but the ecu ones i cant even grip, its ***!!
      Retro!
      Hater
        Your only supposed to take the ones out its just the connectors bro the gray connectors.
          but to take out the ecu u have to take out the WHOLE plate....and then the other side will make the ecu come out...cause i did this at the junk yard...
          Retro!
          Hater
            Just wiggle em. I took mine out awhile ago and it is a bitch, but just keep wigglin'
              well i jsut got done! damn.
              what i did was take out the tcu, and the connectors and take it out individually... so now i have the ecu and the plate.
              then i turned and twisted to get to the screws holding down the ecu....got those out and then exposed the clips...got em and put the new one in.
              but gosh it was hard too..but i got it...
              i drove, and this 93 se ecu lets me take it to 6k rpm instead of like 5700 rpm like my old one...;plus it feels faster..
              ]thanks for the helps
              Retro!
              Hater
                Sweetness
                  6k? Isn't the redline 6250? I recall hitting a fuel cutoff somewhere past that; maybe 6500? Then again, I have/had a 5-speed.
                    hehe redline is around there.
                    but i have an autotragic, well automatic =).
                    before it would take forever to get there, now it just goes hella fast...sweetness!
                    Retro!
                    Hater
                      have you tested the speed limiter feature It should be around 130mph or no limited on some ECU. tested at a dyno or at a track, anywhere else is at your own risk.
                      90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
                      < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
                        gotta love honda
                          hehe hell no im not about to test my speed limiter. it takes me long enough to get to 110...haha and my car isnt that stable at that spedd
                          Retro!
                          Hater
                            Huh. I guess I never tried it on a stock suspension. I've done 115 on mine. Not too smart down the Sepulveda Pass
                              Cb7deathride said wiggle HAHA
                              Henry R
                              Koni/Neuspeed
                              1992 Accord LX R.I.P
                              1993 Accord EX OG since 'o3
                              Legend FSM
