92 Accord EX, back right window. Windows stuck 1/2 way down, took the door panle off to see if it was off track but it doesn't seem to be. Don't know if its a motor, regulator problem or switch. I don't want to go taking off the motor and some how break the glass
All the windows are still greasy but could probably use the tracks greased up again. the back right is just stuck. When I push on the window button I can here a click sound almost like a silinoid click. The window doesn't even try to go up or down anymore. Would like to know what the prob is before taking it to someone and paying a flat fee just to diagnose. All the windows make a annoying squeaky sound when going up or down but not all the time. The drivers side window control makes a weird sound coming from the button. Is there a seperate fuse for each window motor/regulator? All the other windows still work( for now) so is it wiring, motor, regulator? How hard is it to replace the regulator/motor track? Thanks for any help
