AFPR problems
    AFPR problems
    i kinda need help, the adapter piece that mounts to the stock FPR location seems to be leaking/squirting..... i tested the line up all day and still leaking..... also swapped the black round gasket from the stock onto the AFPR adaptor and still leaking.... i asked my brother to check the guage to see if the pressure is too high and he said he couldnt see because he jumped when the fuel sprayed out....
    i cant troubleshoot on this anymore i was thinking maybe the hose diameter im using is too big but i doubt it and all the hoses are clamped and sealed its just the adapter piece thats being a pain
    Have you got the Correct Size O Ring for the FPR.?
      check O-ring and make sure that thing is tight. u can even put a sealant around it if it comes down to that.
      My members ride thread
