just trying to give a helping haynes..lol
those colors could be right, but im seeing a yellow/blue wire to underhood fusebox fuse 28. and then a black/ yellow wire to dashbox fuse 2.
the above was for ecu side of pgm-fi mian relay..i dunno
the yellow/green wire i think you mentioning is the ignition input signal from ignitor to ecu pins a21&a22..if im reading it right.
then there is a yellow-black wire that connects the fuel injector resistor, iac valve, main relay, and part of oxygen sensor. that goes to ecu pin a25& b1.. again if im reading it right.
do you think its worth checking all you fuses, especially fuse 2 in dash, and fuse 28 under the hood?
another question..when you say you have no oxygen sensor..do you mean it not there as plugged in( bare plug) or none all together? if there is none then maybe it getting shorted out by the yellow-black wire since it ties in with the main relay which houses the electronic control unit power supply?
also williamsvt (gotta give credit where its due..) said maybe its a bad tcu.it does have an igntion input black/yellow wires, pins a23&a24 in tcu to dash fuse box fuse 2. chapter 12 page 21 in haynes
im just offering ideas and trying to help..i got all this out of chapter 12 page 8.
good luck tom d :
where would i test for voltage to see if the ECU is working correctly... i have 2 none of them wanna light up the dash.. i have no 02 sensor so it shoulda lit up already shouldnt it have?
good luck tom d :
