My driver's side axle popped out after disconnecting the UCA and struggling to get a shock assembly back in. I guess the weight of the knuckle popped it out. Will I have to replace my axle now?
Axle popped out during suspension work
my pass. axle pops out like its the right thing to do.I need a new snap ring
ILBBPeople I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
did it pop out of the transmission, or did the joints inside the boot pop out? the latter happened to me during my suspension install and i was forced to replace the axle
It popped out of the transmission. Just as luck would have it nobody has a flippin 36mm axle nut, and I REFUSE to get somebody else to fix it.
aero, when you say pop it back in, what do you mean? I just have to get the knuckle off and push it back into place, yes?
Originally posted by gloryaccordyIt popped out of the transmission. Just as luck would have it nobody has a flippin 36mm axle nut, and I REFUSE to get somebody else to fix it.
Originally posted by i97suprattiIf it came out the tranny, did any tranny fluid come out? You might have to refill it. If you lube the end on the axle, you can pop it right back into the tranny.
Originally posted by aerodid it pop all the way out? still trying to picture what happened. As long as the actual joints didnt come apart though, you should be good.
Originally posted by gloryaccordyNo, it seems to be about an inch out...the joints are still on, and the CV side appears to be fine...but on the tranny side there's a ring of grease about an inch deep, and there's some axial play (in-and out), which, considering the weight of the knuckle assembly would lead me to believe that the tranny side of the axle came apart INSIDE the boot. Is that possible?
OK, last call...anyone got air tools they'd be willing to rent in NYC? I can't lower the car back down to loosen the axle nut as the suspension won't line up with the axle out of place...if nobody does then it looks like I'm getting it towed to Pep Boys...
