OK, I'm gonna keep it funky...I did a coolant flush and hose change, and for whatever reason a significant portion of my negative battery cable is exposed down by the...starter?...so when I disconnected the lower hose coolant went everywhere, I'm guessing completely corroding the wire. Hopefully that's the only problem...
But the thing that gets me is that I just replaced that cable not even a year ago, because it was rotten from what I'm guessing is the same problem. And I distinctly remember the new wire being sealed the whole way through. So my question is could coolant 1. strip the rubber off the wire, and 2. corrode the wire to the point that it couldn't start?
HOLY SHIT...I just remembered I have the jumper cable...I'm gonna try and "jump" the negative battery cable to the alternator ground...
