so i was driving home from wrok today and all of a sudden my oil light started blinking so i pulled over and everything was fine . full oil , no leaks , no weird smells or sounds. the light comes and goes and only usually comes on during idle and when i rev it in neutral. what coiuld this be and how can i find out what it could be? and what are the estimated prices to the parts to fix it? thanks
oil light
Theres an oil pressure sensor on top of your oil filter i think or it could be your oil pump took a shit if everything looks fine. But it sounds like the sensor might be bad.
well yesterday my oil light came on and I went out and purchased a new VC gasket cause I knew it had a small leak, PCV valve since I was taking off the cover and I brought a oil sensor. On the way home I did a oil change when the light came on. But to no success the light still remains blinking. I checked the valves and the oil is present and I constantly check the dipstick for oil. I have had a dent in my oil pan pushing it no higher then the height of a dime and its been there since GOD talk to Moses. I can not find a answer to why this is happening other then thinking that I recently changed my entire exhaust from headers back. But still that shouldnt really effect the oil pressure. I am gonna try to do a oil pressure test tomorrow but feel its a waste since I know my engine is getting fresh oil on the valves. I feel the pressure from the PCV valve blowing. I will loose my freaking mind if I now have to change the oil pump and so forth. I even went so far as to resetting the ecu thinking it may need to re adjust the for the CAI and Exhaust changes. O yeah I took each plug out and cleaned them to see if oil was present but none found. I even did a rapid coolant flush from the Radiator to make sure no oil and my car doesnt smoke at all other then the fact that it has no real cat but the Egay one. The funny thing is now my car idles like a dream so smooth I cant really feel it in the steering wheel. Holding its idle at 750 to 800 rpm like I feel its suppose toLast edited by Abeerdrinker; 04-23-2006, 07:20 PM.WHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
Originally posted by Abeerdrinkerwell yesterday my oil light came on and I went out and purchased a new VC gasket cause I knew it had a small leak, PCV valve since I was taking off the cover and I brought a oil sensor. On the way home I did a oil change when the light came on. But to no success the light still remains blinking. I checked the valves and the oil is present and I constantly check the dipstick for oil. I have had a dent in my oil pan pushing it no higher then the height of a dime and its been there since GOD talk to Moses. I can not find a answer to why this is happening other then thinking that I recently changed my entire exhaust from headers back. But still that shouldnt really effect the oil pressure. I am gonna try to do a oil pressure test tomorrow but feel its a waste since I know my engine is getting fresh oil on the valves. I feel the pressure from the PCV valve blowing. I will loose my freaking mind if I now have to change the oil pump and so forth. I even went so far as to resetting the ecu thinking it may need to re adjust the for the CAI and Exhaust changes. O yeah I took each plug out and cleaned them to see if oil was present but none found. I even did a rapid coolant flush from the Radiator to make sure no oil and my car doesnt smoke at all other then the fact that it has no real cat but the Egay one. The funny thing is now my car idles like a dream so smooth I cant really feel it in the steering wheel. Holding its idle at 750 to 800 rpm like I feel its suppose to93 Accord- SOLD
94 Civic- F22a1 Swap, current DD
I have changed the sensor already but still have the blinking aka idleing oil light. I also changed the vc gasket and PCV valve but nothing as worked at this point.WHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
Fyi
The low oil pressure indicator light works in two ways.
It will flash continuously following a momentary loss of
oil pressure, or it will go on and stay on with a complete
loss of engine oil pressure.
the engine (ground).
When the engine first starts, before oil pressure rises
above 25 kPa (0.25 kg/cm2, 3.6 psi), current flows
through the low oil pressure indicator light and the engine
oil pressure switch to ground. This tests the circuit.
With the engine running, voltage is applied to the flasher
circuit of the integrated control unit. With normal engine
oil pressure, the engine oil pressure switch is open and
the low oil pressure indicator light does not go on. If the
engine oil pressure switch closes momentarily (more than
0.5 seconds), but then opens again, terminal "A1" will
sense ground through the switch. The integrated control
unit will then provide and remove ground for the low
oil pressure indicator light through terminal "A1". The
light will flash on and off until the ignition switch is turned
to "Off".
If engine oil pressure falls below 25 kPa (0.25 kg/cm2,
3.6 psi) and does not increase, the engine oil pressure
switch will stay closed. The low oil pressure indicator
light will go on and stay on.
To test Sensor:
Remove the YEL/RED wire from the engine oil pressure
switch.
Check continuity between the positive terminal and
1)There should be continuity with the engine
stopped.
2)There should be no continuity with the engine
running.
continuity-all that means is to see if there is voltage going to the sensor, take a volt meter and put it to the setting where it shows if there is voltage present(not messureing it, just seeing if voltage is pressent), i think its one turn back from the off, at least on mine it is)...Last edited by ehulst; 04-23-2006, 07:52 PM.93 Accord- SOLD
I have narrowed the list down to just a few problems that could make my oil light to come on at this point.
One
The opening around the oil sensor is leaking
Two
The oil pan might need to be re tighten
Three
The oil pickup has seen its final days or crap in my oil pan
Four
The possiblity of a short in the oil sensor(Doubt it but who knows)
But I can say this I had no choice but to drive my Accord to NYC from south jersey in traffic to and from and I didnt have not one problem except the oil light flashing when coming to stop and go traffic. 1 1/2 hr drive each way and not one sign of failing pressureWHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
Its your oil pressure switch. Its above the oil filter. Its roughly $30 at Honda. Be sure to use a deep socket to get it off.
Mine went bad in 2003. Took maybe 20 mins to change.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
2008 Ford Escape XLT [bone stock]
2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
Originally posted by ACCORDianateIts your oil pressure switch. Its above the oil filter. Its roughly $30 at Honda. Be sure to use a deep socket to get it off.
And its a 15/16 socket that I usedWHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
Originally posted by AbeerdrinkerDude ...light is still ...only 7 bucks...Store...15/16 socket...Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
well I found my problem or what I feel is the problem to my oil light blinking. I found that the rear balance shaft seal started leaking. I first thought it was from the valve cover or oil pan but after removing the timing cover and so forth I found what I belive is the source of my problem. I pray this repair will fix my motor and that in the blinking of the light wasnt because of something else like bearings or etc. Funny enought after I removed the everything I found that my balance shaft was off by one tooth when I had it replaced last summer with the timing belt and water pump.
Btw
I wish this problem now had happen sooner so I can go back and kick the shop arse for f ing up the job.WHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
Originally posted by 93accordtunerso i was driving home from wrok today and all of a sudden my oil light started blinking so i pulled over and everything was fine . full oil , no leaks , no weird smells or sounds. the light comes and goes and only usually comes on during idle and when i rev it in neutral. what coiuld this be and how can i find out what it could be? and what are the estimated prices to the parts to fix it? thanks
1994 Accord Coupe LX BPU
1991 Galant VR4 #1395/2000 Sold
1990 Accord EX 4DR Sold
1990 Galant Base Model junked it
1991 Accord EX 4DR gave away
