hello everyone let me start off by saying that all the warnings about discounecting the battery while running is true.... after doing so i had to replace my ECU and Alternater. now my car's battery light and ABS light won't go out. and every 2 - 5 miles shuts off. and won't start back up for atleast 20 mins. i checked for the cell code once and nothing showed up. then after it stalled out i check the code again it came up 15. now how do i fix this problem?
how do i repair cell code #15
Originally posted by kulet562hello everyone let me start off by saying that all the warnings about discounecting the battery while running is true.... after doing so i had to replace my ECU and Alternater. now my car's battery light and ABS light won't go out. and every 2 - 5 miles shuts off. and won't start back up for atleast 20 mins. i checked for the cell code once and nothing showed up. then after it stalled out i check the code again it came up 15. now how do i fix this problem?
Reset the malfuntion light system. There is a fuse under the hood in the fuse box there. It's the back up fuse in the upper right hand corner when you're standing at the front of the car. It's a 7.5 amp fuse. Anyway, remove that for 10 seconds reinstall it and turn the car on and run it at 3,000 RPM for a little while and see if the malfunction lights come on again.
If it does come on, you're going to have to run through some diagnosis. If you want the diagnosis chart shoot me a PM and I'll send it to you. Good luck.wat
