disabling fuel system for compression check?
    what do you pull to diable the fuel system becuase the haynes manual says pull the fuel pump fuse but i think they mean the main relay but i really dont know, so if n e could shed a little more light on the situation i'd appreciate it
    p.s. i've tried the search button, so dont worry this is my last resort i usually dont post a thread unless i really need to
    -sean
    Members ride 15.927 @ 86.76 (f22a1)
    Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
    Arcadia Green Crew #10
    Just pull the ECU fuse. Its a 10amp under the hood. Really easy
      thanks, me and deev are gonna compression test our cars sometime soon and we were stumped so thanks
      -sean
        I just left mine in. You could smell all the gas. Only spontaneously combusted once :P
        Originally posted by DoctorCipher
        ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
          well your also supposed to disable the ignition before the coil but you do it watever way you like
          -sean
            taking the ecu fuse out also cancels the spark
