Hi and TIA !
1990 4-Dr. Honda Accord EX
Problem: Car will turn over no problem but won't start.
First thing I checked was spark. Pulled a plug wire, cranked motor over NO spark to screwdriver I was using for a ground.
Second step check coil for power. Power present at yel/blk wire + terminal with key at start position.
Step 3 test coil resistance. Resistance between + and - .8 ohms within Chilton's manual specs. Resitance between + terminal and secondary winding terminal 10,900 ohms. Chiton's manual calls for 12,800-19,200 ohms.
Could this be my culprit ? My police mechanic friend at work said you can't always rely on a resistance test on a coil ?
Step D Igniter/ICM Test. Chilton's manual states: Remove ignitor wires. Turn on ignition. Check for voltage at blk/yel wire. CHECK, VOLTAGE PRESENT.
Check for voltage at wht/blu wire (ignition on). NO VOLTAGE PRESENT. If voltage is not present, check the wht/blu wire from the igniter to the coil (didn't I just do that) an test the ignition coil.
Step 5. Turn the ignition off. Check for continuity in the yel/grn wire between the igniter and the ecu. How do I check that ? Yel/grn wire to ground for continuity. I didn't do because of the confusion (hope) that step 4 resulted in and fully understanding step 5.
Help me please. I'm thinking it's the coil but need to be 100% sure since you can't return electrical parts and I had to borrow $80 bucks from a friend at work til next payday. Thank you sooooo much Albert.
Any suggestions would be greatly appreciated !!!
Thanks again
Jeff Gray
Thanks again
Jeff Gray
