I put in a new clutch and flywheel in 1991 HA LX. I got about 400 miles of straight local driving and 10 miles on the highway but this morning I took the highway again to see how well the clutch break in is going .An I noticed when I gotten around 60 mph and let the rpm's get to 4 to 5k.Depressed the pedal to let it idle down a bit and then repressed the pedal the clutch slipped from 3k to 6k until it caught again. I know the tranny is fine and it can only be the clutch. But I dont know what I could of done wrong. I did everything to factory spec's when doing the job. I took 2 days of slow working to get the job done once so that I wouldnt have to change again for another 8 years but it keeps slipping. I have all fluids at the level and bleed the clutch until clear fluid was left. I adjusted the pedal so that its soft when engaging and then made it harder but it still slips. Anyone have a problem like this before? and what did you do to correct it ? I feel as if the pressure plate is failing but I double checked all the part numbers to make sure they are the right ones. I dont want to take it to a tranny shop cause they are gonna charge me the same price as if they are putting the clutch in. If you need more info let me know.
I have a manual Flatbed,Mx-3(v6),Legend and I converted my old Fleetwood caddy. Clutches normally last around 6 to 8 years except in my truck which I got about 3 years out of it but its new and I know I tow alot. I dont think I could of broken it in wrong and I changed clutches since god knows how long but this time something went wrong but maybe I am getting old.
