so i noticed today on the belt cover that the person who changed it wrote the mileage it was changed at..this is in km btw...you guys think i could ride it out for another 50k? i drive pretty easy on the engine and shift at about 2-2.5k rpm...
timing belt changed at 41k now at 204k... time to change timing belt???
Originally posted by eightyfour84wont mess up the engine eh? i heard along as the rpms aren't too high when it breaks i should be ok...
Originally posted by DoctorCipherThis is true. When it does break, remove the upper timing cover and crank the starter for about 15 seconds. Do this 3 or 4 times...it will eject the old timing belt pieces from the exposed area and make the new belt installation easier.
Originally posted by AccordWarriorReally? My friend snapped his in his D at like 2500 and the motor went blooey.
Originally posted by eightyfour84so i noticed today on the belt cover that the person who changed it wrote the mileage it was changed at..this is in km btw...you guys think i could ride it out for another 50k? i drive pretty easy on the engine and shift at about 2-2.5k rpm...
Are you serious?? You should really get it changed. I think it's every 60-90k I heard, but observe the belts to see if there are cracks and what not.hahahahah
Originally posted by DoctorCipherAnything under 4k and you're in the clear.
I read my haynes book and it looks hard as hell to change the timing belt matter in fact i have a blown a1 with a hole in it laying in are shop and the guy put a new TB on it so im going to use that one but i think i have to take of the under drive pully. my motor that i just put in my other car has 250,xxx
and i dont think nothing has been changed on that thing.www.myspace.com/spayellowaccord This is mine!
www.myspace.com/autorevolution This is our car club!
1. 1992 Spa Yellow Accord EX 5spd coupe. I <3 My CB'S
2. 1992 Grey Honda Accord DX 5spd coupe. I <3 My CB'S
3. 1992 ? Honda integra Xsi DA6 im so jdm i sleep on my right side.
4. 1993 Black Honda Civic Hatchback. love my EH
Originally posted by DoctorCipherThis is true. When it does break, remove the upper timing cover and crank the starter for about 15 seconds. Do this 3 or 4 times...it will eject the old timing belt pieces from the exposed area and make the new belt installation easier.www.myspace.com/spayellowaccord This is mine!
Originally posted by DoctorCipherDoesn't matter... when you are done with that procedure, carefully reset engine timing according to the book and put your new belt on.
what about the other about driving on the highway at 3kwww.myspace.com/spayellowaccord This is mine!
