The title says it all... my new 12lb flywheel has no timing marks. I marked the dizzy before I took it off, so it's running just fine now... but when the time comes for adjusting the timing, or replacing the dizzy, it's going to be a pain! Are there other ways to do it?
XTD flywheel has no timing marks... are there other methods of setting timing?
This is a good question because my Exedy didnt have any when i installed it.
and i was looking at my craftsman catalog and found this Innova digital timng gun, for 149 bucks. Can read about it at this link, i cant find it at sears.com
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4599420204H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
^ yeah that is a good way, if you havent put it all together like some of us..
im still not sure if the digital gun that i posted still needs the marking on the flywheel or not, but im pretty sure it doesnt..H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
yup keep it real.. fuck trying to mark shit with it all put together.. :PH22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Never had to do this but here's what I suggest:
Cylinder 1 should be at TDC when your timing marks (the one that should be on the flywheel) are on the indexer. So, pull the plug in cylinder 1 and place a clean wood dowel or something like that down through the plug hole, and touch the top of the piston, make a mark on the dowel near the top of the valve cover for reference. Have a buddy turn the crank from the end pulley with a ratchet/breaker bar and when the dowel reaches it's highest point you're at TDC on #1. Then, scratch a mark in the new flywheel....1992 Accord LX - SOLD
Originally posted by maroonaccord2.2Never had to do this but here's what I suggest:
Sort of like this explanation
Would This Work by ILBB
