Manual transaxle
    Manual transaxle
    OK im an idiot, but with the manual transaxle (transmission) it says to add just regular motor oil, correct? i have been using valvoline in every car i've owned and swear by it (motor not the transmission). since my transmission has 196k miles on it should i use the maxlife motor oil (high mileage)? could i use sythetic? what is a good weight to use? thanks, please keep bashing to a minimum.
    That was recommended in early 90's and now they make the Honda mtf specifically for your transmission.
      Usually i just use honda MTF. They say you can use 5w30 or 10w30 oil also. IM not sure which one.
        10w30 oil will work fine...
        although you can't go wrong with honda MTF or GM synchromesh
          i use the honda MTF cause i got it for free, but just 5w30 before that
          dirty accord->
          http://www.cb7tuner.com/vbb/showthre...threadid=13407
          crappy website
            id suggest using MTF or synthetic gear fluid if possible.
            it felt much different for me
