So i bought my Accord w/ a burnt valve and it ran fine just kind of stumbled cause of the low comp on the #4 cyl. So i removed the head and had valve seals, exhaust valve guides, and 3 exhaust valves replaced. Got the head back and bought a Felpro Gasket set replaced the Headgasket and majority of other seals. After start-up the car is pouring smoke out of the exhaust constantly. Checked the valve seals w/ a Borascope(sp?) and they dont appear to be leaking. Is it the headgasket not seating right, and if so how does the oil make it past the water jackets surrounding the cyl? IDK, just askin for help before guessing/replacing parts. Any help is greatly appreciated.
Thanks
Thanks
