Taillight Problem
    Taillight Problem
    when i push on the brakes only the two left tail lights work the 3rd brake light and the whole right side doesnt work. but when i turn on my headlights (also when the tailights come on) everything works from the two left and the two right its just when i brake the left side only works i also have the brake light indicator on when this happens and im guessing thats cuz of the 3rd brake light but i dunno why the whole right side is out....i also checked but all the bulbs are fine i even switched the right brake bulb to the left and everything works i just dont know why they dont work when i brake... please need help right away cops here in sd are so anal about this kinda stuff...thanks
    Beast: Evo X
    Daily: 93 Accord LX Wagon
    please anyone?? help i just dont know what to do?
    Beast: Evo X
      Check the fuse for the tail lights, and test the wires that go to the tail lights. I've had that problem where the light on my lid didn't work and I replaced a fuse and they all went back to normal.
      I still have the bulb indicator light on in the dash because I don't have a light in the back window since I have a light in the spoiler.
        i have checked all the fuses.. and if i did miss one what would it be under? there is no fuse for tail lights.. there is one for signal lights... i checked under the hood and under the steering wheel column.
        Beast: Evo X
          I dont remember whether or not the 2 sides have seperate grounds or not, you may want to check that out, make sure all the ground wire are still intact.
          My song of the week (or till I change it): Snow Patrol - Take Back The City
            hahah, i did the same thing. the brakelamp indicator finally went out a couple of weeks ago since i disconnected the third lamp back in '98 or '99.
            S A N D I E G O
              hmmm... interestin
                theres to many black wires to find the ground for the taillight and most of them are wrapped so i dont know which one im looking for any info would help
                Beast: Evo X
