hey everyone, not sure if this in the right spot, but i couldnt decide where to put it
ok, today driving home my check engine light came on, then D4 started blinking continuously. Every time i would come to a complete stop the idle would bog down very low, and when i applied gas it would come close to stalling out but never did. This happened a couple days ago too. i was in a 7 11 so i just turned it off, turned it back on, still was doing it so i revved hard a couple times, turned off, on again then no problem. everything was fine.
now i just got it home, drove hard on the interstate and when i pulled off the exit the light and D4 were still going but i could tell it wasnt bogging down as much at a complete stop. got home, turned it off, then on again and no problem
could be a sensor, but im not sure. maybe the TPS was what my friend said today at work (throttle positioning sensor?)
HOWEVER, i also have been having problems with my positive clamp on my battery coming off. its tight as it gets but sometimes it will just slide up and off. I usually find out it did it when i go to start the car and nothing. so i just walk around pop the hood and push it back on. i need a new clamp. could this somehow affect a sensor?
one last thing i think it might be. I got a new neon tube for my front kit. i installed it Saturday, but due to lack of time i just wired the rocker switch directly to my power and ground on my amp (i know i know) I forgot about it and have been meaning to run its own power and ground. Now, i talked to a guy about it and he said he didnt recommend doing it that way cuz he did it in his 5th gen (same thing, wired it to his amp) and he said it made his sensors and gauges do some crazy stuff. I just remembered that today so im wondering if this could also be a side effect?
one last thing. in neutral the idle is right where it should be. only when i put it into a Drive position.
thanks in advance guys
