A/F Guage
    A/F Guage
    I am looking to install an Air/fuel guage in my cb7. Anybody have pics of mounting locations. Where is the best place to run the O2 wire into?
    Also, what color wire is the o2 sensor wire? I will check over at www.the12volt.com
    Thanks
    I got a sweet idea cookin' up
    the ones ive hooked up, ive tapped into the wire somewhere in the engine bay.. people say its "easier" to do it right at the ecu, but something just tells me you shouldnt add wires right next to it.. the white wire is the one you need to tap into..
      You splice it into the white wire on your ecu. There has been like 2 threads on this in the past.
        i think we did it to the 02 sensor in the engine bay. that was on a civic though
        Retro!
        Hater
          I did a search on it earlier but nothing came up. Just a couple cars in member rides that had a a/f installed.
          If you were too hook up to the actual sensor, would you want the header o2 sensor or the cat sensor?
            you only have one o2 sensor buddy..
              Sorry, I havent ventured down into my exhaust.
