my corner lights won't come on or blink when i use the turn signal. the headlights work fine and the rear turn signals blink. the front bumper lights/turn signals are not connected, but it has never been a problem before. i have checked the fuses labeled corner lamps(i think) in the driver side fuse box. i haven't checked all four corner and signal lamps but i don't think all would go bad at the same time, but i would still check them. does anybody have any suggestions as to where i should check next? any help will be appreciated. thanks!
lighting problems
check the bulb...haha sometimes when you think about it, you dont notice that they are all bad until later.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
found the problem! blown fuse in the engine bay fuse panel, the one labeled small light. when replaced it also fixed my rear defroster problem(won't come on before, figured it was the fuse also). it also fixed my intermittent wiper problem. to say the least, i'm pretty surprised that the fuse labeled small light is tied in with other functions.
but now there's a new problem....when i put the face on my radio and turned it on it blew the fuse again. so now i know what blew that fuse, just got to figure out how. i'm thinking there's a shorted wire in the back of the radio from pushing it in when i installed it(i think that's where the problem started.....me doing the installation..lol)
anyways, thanks guys for all the response.
