Is it ok to hook up an S-Afc to a chipped P06 ECU? I was thinking of getting one. Thanks
S-Afc II question.
Originally posted by high cif it is chipped, i assume you are running uber, so why would u need a safc?You have been defeated by a car with child locks, how embarassing...
"I noticed my f22 felt "healthier" until it blew up." <Myk>
well uber is vac/boost dependant (dumps in fuel depending on how much vac/boost it is seeing at diff rpms) and an safc (if the same as a vafc) is just rpm dependant, so yes it will work, but i think it would be easier just to buy a chip burner and burn the chips yourself - eliminating the need to go to florida. Because tuning with an afc is hard and will result in a fucked up engine in time...My baby laying down some power...
http://www.youtube.com/watch?v=kd_Q8HSIyqA
Don't do it alex, your turning your back to the best solution again. Buy a chip burner, its still cheaper the s-afc. Like high c said uber is load and rpm based. If you start tricking the ecu with the s-afc (BTW thats exactly what the s-afc is...a trick) then your going against how the car currently runs. Go to moates.net, buy a burner. Simple as that.Knowledge is power...in EVERY sense of the word
Neat, is this what you're talking about?
http://www.moates.net/product_info.p...products_id=48
(Sorry if thats a dumb question, haha.)1992 Accord LX
(Sorry if thats a dumb question, haha.)Knowledge is power...in EVERY sense of the word
Originally posted by Alex EXSo even if I tune the AFC on the dyno, i'll still mess up my car? Or will it just not be as effective as uberdata?
at least that's how I understan dit... I could always be wrong...
but it really is like using 2 tools for the same thing...
I've done it myself but it was only because I wanted to play with the AFC a little... and I'll probably continue to do it since I'm NA... until I start approaching that edge a bit more...
on the other hand... my car did end up with a broken timing belt... although unrelated... but still worthy of note I spose... lolLast edited by ZigenBallZ; 02-17-2006, 05:44 PM.RIP Lifsatrip7
