#1 Fuse Blown
    #1 Fuse Blown
    I took my battery off, and when i tried to put it back on i blew the #1 Fuse. Should i just replace it with another #1 Fuse?
    Yes! but make sure it is of the Same Ampage "80 Amp". Also make sure the POLARITY of the Battery Terminals is correct before reconnecting the terminals again. The POSITIVE Battery Post is LARGER than the NEGATIVE Battery Post. Never rely on the color of the Battery Terminal Covers or Wiring with the CB7. Both POSITIVE & NEGATIVE Leads are Black.
    POSITIVE Lead goes to The Starter Motor, NEGATIVE Lead goes to Transmission or Engine Mount & Inner Fender.
    Follow the leads from the battery to locate which is which.
    (All this is assuming you are not already aware of this)
    Just hope you haven't fried the Main EFI Relay and Alternator Diodes!!
    -GEOFF-
      Guru pretty much nailed it.. also on the battery close to the poles there is a + sign positive and a - sign negative..
      Nice Asses I Like
      Smart asses I don't
