i got my cb7 used and i noticed that there are a cord under the driver seat (like the one on the seat removal diy), and a wire under the passanger seat thats not plugged in to anything (like the one under the passanger seat on the diy seat removal). if someone can help me and let me know where these go. thanks
i have a question
more details to my question, so yall can help me more
my car is a 92 2dr ex. i have a wire under my driver seat that is unplugged and its been unplugged since i got the car pic is of driver side seat wire...http://www.cb7tuner.com/vbb/attachme...tid=1497&stc=1
and the passenger wire looks like... thishttp://www.cb7tuner.com/vbb/attachme...tid=1496&stc=1
please help me out , thanks.
Drivers side is the seat belt indicator connector. It goes to the underside of your seat where you should find a female connector from the belt buckle. The passenger side is the diagnostic plug for your ABS II system. It appears that someone has had your plug disconnected from its holder for some reason because the wire should be completely hidden under the carpet. The ABS plug is orange as with everything else on the ABS system. With it, you plug in a special tool only available from Honda to test the wheen sensors/plusers, the modulator, ABS pump and ABS computer.
