Warning Lights
    Warning Lights
    Hi guys, I'm new here! I got myself a 90 accord 2.2i Auto 4ws (i'm in england), and it has many problems, but the one i come to you with today is this...
    When i start the car, all the lights flash, then go out as normal..I can press the brake pedal and have the parking brake off, no lights come on the dash. Until....Once i take it out of park and touch the brake, the parking brake light and the brake light warning reminder illuminate...The after a while the yellow ALB light creeps on ..I just need to put the cruise on then i've got a disco...
    Anyone heard of this?
    Check all the Brake Light Globes (Left, Right & High Mount) are working properly and have the correct type globes in them. Also check the Brake Light Switch Circuit. The ECU references the Brake Light Circuit for Correct Idle and C/CTRL operation.
    -Geoff-
      Thanks Man, I'll give that a try next time I'm off and let you know how it goes!
