Want to see if anyone has ever encountered this problem. Searched a few forums with no luck.
My CEL has come on 2 times randomly... I hate seeing a CEL. Went to check the code, and when it is jumped, the light blinks very quickly once every 5 seconds, and is about half as dim as it usually is.
If you just go to start the car (CEL not jumped) the light shines at correct brightness.
h22 w/chipped p28... has run fine for a year.
checked ecu ground.. cleaned the already clean connection
new ecu fuse
swapped chips in ecu
and still have the same problem. Car runs fine, any ideas?
new ecu fuse
