After driving to school this morning all of the sudden my gas pedal lost all feeling whatsoever. What i mean is that now, when i hit the gas even just slightly, theres no resistance. I can put the pedal to the floor with almost no effort at all. I should say that my tranny is on its last leg, and that i need to swap to a 5spd BAD, but do u guys have any ideas why this is happening?? Trottle cable maybe? Any help is awesome
Wtf!!!
It might be that your throttle cable has come loose...check to see if the thingy is tight on the throttle body.Former Ride:
93 Accord Coupe
Jdm H22 w/ LSD
Type S pistons and cams
New Ride:
Bone stock 99 2.3CL
Black on Black Leather
5spd
"Experience: that most brutal of teachers. But you learn, my God do you learn."
C. S. Lewis
Originally posted by exratedaccord93It might be that your throttle cable has come loose...check to see if the thingy is tight on the throttle body.
on the throttle body there is a goldish colored rotor. it has 2 cables coming from it cause ur automatic. look to see if the cable on the drivers side of the throttle rotor has come loose. if it has, turn the rotor and weave the cable back into it.
Originally posted by AcclipseH23You had something going when you said throttle cable. Did you pop your hood and inspect it? The throttle cable is not gonna create much pedal difference. However there is a pedal difference.
Originally posted by 93accordexcoupeyea but its more than check the thingy on the throttle body.
it makes a huge difference dude, i had my off and the wieght of my shoe alone made it sink to the floor
yur right, going over bumps the weight of my shoe makes the pedal move a ton. I looked under the hood right after i posted and noticed the throttle cable by the gold rotor is loose as hell. I can only describe it as loose right by the rotor, where the cable hooks up to the back of it. Any idea how to fix this or am i fucked?
its hugely related. you're cables are all messed up. you need to synchronize your transmission control cable and adjust your throttle cable to 2CM of slack. that trans. control cable can MAJORLY affect the way the transmission shifts and acts.Last edited by xaxis360; 02-02-2006, 05:46 PM.
