what are some good aftermarket spark plug wires?
performance spark plug wires
Re: performance spark plug wires
Originally posted by dj justice
what are some good aftermarket spark plug wires?Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
how do you know when you need new wires? mine says 1990 on it hahaha...i have no clue if its been changed.
the book said use a ohm tester and if its under 20000 ohms resitance then your ok....
i heard about color changes tooWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
theres alot of aftermarket plug wires out there but NGK always gets thumbs up. I run Crane 11.5mm that I paid $150 bucks for because I thought the most expensive is the best. turns out their really good noise suppresors and there good for high voltage ignition systems which i dont have yet. you would be in good shape w/ NGKhttp://members.cardomain.com/jerizzle
Andrew
Honda OEM (Sumitomo).
Performance spark plug wires, especially with the quality of the HOP ignition system, are a joke.
i heard about color changes tooVisit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
