My problem is that my speedometer does not work could you guys give me a couple of suggestions.........What could it be
Speedometer....
Find out what code is being thrown when the Check Engine Light comes on. If it's a 17, then it's your VSS like 91accord4door said. Replacing the VSS takes ten minutes and is pretty cheap.
It's worth doing because the VSS affects your idle. Also, your cruise control won't work without a good VSS.- Ghosty
WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
The VSS usually quits after about 90-100k miles. If you swap one in from a motor with ~100k you may have to replace again later! You can buy them online for about $40 aftermarket.
yeah i have the same problem.. i kind of fixed mine though.. im not sure if it was just a coinsidence though.. my power steering fluid was real low and after filling it my speedometer works most of the time.. not sure it was just an accident.. but it worked for me... good luck!!!R.I.P 90 lx fodo ..my baby!
R.I.P 00 DC2 gsr
R.I.P 92 lx fodo
R.I.P 91 dx fodo
rockin a 2007 ridgeline rtl
