First up i want to thank god for giving us this site. You dont know how much help its been.
OK now to businss, I have a 93 honda accord lx. It has the following mods
MSD 6al ignition module
blast 2 coil
NGK Iridium plugs
NGK Spark plug wires
Bomz Cold air intake
OBX Headers
Test Pipe
2.25 mandrel bent cat back exhaust, (Fire ball)
And a few interior mods.
Ok I bought the car 2yrs ago stock and have been modifying as i can. It has 183000 miles on it. Its does have a lil oil in cylinder 2 and smoked a lil upon start but other then that no probs.
The other day, the car started making a loud noise under the hood. It sounded like the distributor area was were it as coming from. My dad checked it out and he said it had no knock and that it needed to be checked. The next day i had to run a eron and i ran to a friends house, the car drove fine,(excluding the sound) an hour later I start the car up and runs awful. It sounded like some one put the plugs on the distributor in the wrong order. I though i only live like 5 minutes hinme so i risked it. I took off slowly and it ran awfully, backfiring and couldnt really put it to low rpms cause it start to die. I pulled to a light and at idle it died. It would not start again. No smoke no nothing. It turns over but nothing else. No check engine light nada. The next day i recheck it, still wont start. I pop off the fuel line and test it and its getting fuel. I popped off the distributor cap and theres oil in it as well as lil shaving of it looks like metal in the cap. The rotor of the distributor is liek white baked. I popped the roto off and replaced the cap and roto and it still wont turn over. I checked the distributor roto and its not moving when i crank it. Some one told me its a burnt out distributor due to the MSD/COIL/PLUGS/WIRES Sending high voltage threw. Another says my timing belt is messed up (i havent had a cahnce to check it yet) another says it sounds like internal engine failure
I lovethis car and would really like your opinions. You guys have never let me down in the past.
Thnk you
AL
blast 2 coil
NGK Iridium plugs
OBX Headers
Test Pipe
Thnk you
AL
